YAHOO.lang.augmentObject
Click the button below to call methods on an augmented static class.
YAHOO.lang
comes bundled with the YAHOO Global Object.
If you are using any other YUI component on your page, you should already have YAHOO.lang available.
Static classes, such as YAHOO.util.Dom
, are implemented as object literals with keys corresponding to public class methods. As such, static classes aren't candidates for instantiation or prototype extention. To add functionality to static classes, you need to work with the class's object literal.
In this example, augmentObject
is used to add a set of behaviors to a static class.
We'll create a namespace YAHOO.example.addons
to hold common packages of static methods and members. In this namespace, we'll create a set of logging functions.
Now a targeted class that would benefit from these methods can add them using augmentObject
while keeping its source focused and unique.
YAHOO.lang.augmentProto
augmentObject
works in similar fashion to augmentProto
. In fact, augmentProto
uses augmentObject
under the hood. However, rather than adding functionality to class definitions (i.e. function prototypes), augmentObject
can work with any object, including object literals and class instances.
See augmentProto
and extend
for other techniques to help manage your code structure.
Copyright © 2008 Yahoo! Inc. All rights reserved.
Privacy Policy - Terms of Service - Copyright Policy - Job Openings
